Aluminum full length finger pulls
10/5/18
Chris
Hi,
We are bidding a sizable residential project with the fingerpulls shown below.
Some of these will be powder coated.
I'm wondering HOW TO? The "T" molding type barb gets inserted into a slot obviously but when the door is open you'd see the slot unless you do a stopped slot and remove some of the barbed part on the aluminum extrusion. Seems super labor intensive and hard to do pefectly with potentially filing or cutting into a seen part of the aluminum. Powder coat will add about 2 sheets of paper thickness as well so were concerned about sizing the slot...oversize slot, glue and clamp??
How are you guys doing this? Hafele had no input BTW.
2018_Deco_Catalog_062918_285.pdf
10/5/18       #2: Aluminum full length finger pulls ...
chipbored
Oh yeah they are a pain in the butt. super labor intensive.
Maybe you could put in a price to do a square edge door with a 25mm color matched rail behind. Same effect really
If the doors are edged. You can run the slot right through and then edge over it. If it's a painted door then you have to rout the slot and stop short of the edge.
...and yes you have to notch the tongue short on the extrusion.
Depends what material the door is but
I would keep the slot tight and just a bit of glue in there at final fit-off.
I think you'll be ok with the powdercoating just cut the extrusion .5mm shorter than the door.
10/6/18       #3: Aluminum full length finger pulls ...
Chris
Thanks chipboard. Calibrated sheets too. Sounds like something will go wrong with a whole house full of these doors and fronts. Thanks for your input. Good call on the colored rails!
