Sugatsune hinges
12/18/18
Matt Calnen
Hello all, I have a job coming up where we are taking an 8’ by 2’0” by 1 3/8 thick door and need to blind hinge it. The contractor wanted to use a Soss type hinge. I have seen those Sugatsune hinges with some adjustments, but have never used them. I am very familiar with Soss hinges, and wondered if the Sugatsune are a quality product, and any tricks to installing them? Thanks
12/18/18       #2: Sugatsune hinges ...
David R Sochar  Member
I have not used the Sugatsune, but I have used Tectus.
Tectus are the same type of hinge - blind, 3 way adjustable, heavy duty, no sag - as Sugatsune.
Tectus also has template rental available if you like. Makes it easy to route. Makes Soss hinges look like crap.
Tectus Hinge Install
1/31/19       #3: Sugatsune hinges ...
Matt Calnen
Thanks for the advice David. My project just got installed. After researching the Sugatsune and Tectus hinges, I went with the Tectus. As a lover of shop fixtures and a jighead, I was bound and determined to make my own templates for the mortises. The Tectus 340 hinge only required me to make one template, with some stops. The Sugatsune has different width hinge “leaves” so installation would not be so straight forward. The contractor that installed them said they are awesome and worth every penny.
2/1/19       #4: Sugatsune hinges ...
Matt Calnen
