sloped hood vent access
12/31/18
Brett
Hey guys,
Just wondering what some of you do for vent access on sloped hoods. We have done many hoods like this(see pic) and some heating/cooling guys and have not had an issue hooking up venting and some have said they need an access panel of sorts. My guess is some use flex tubing and others prefer to steer clear from flex tubing.
Another option, I think, would be to have all venting hooked up and then slide the hood over vent and venting but this may get tricky.
Just want to see what the rest of you may be doing in this situation.
View higher quality, full size image (960 X 960)
1/1/19       #2: sloped hood vent access ...
I tell the hvac guy, good luck.
Sliding the hood over the liner would be the easiest for hookup, but what do you do about anything other than paint on the wall, and any mouldings at the ceiling?
1/1/19       #3: sloped hood vent access ...
Matt Calnen
I do two piece hoods most of the time. The lower section holds the body of the hood, then the tin knockers can easily hook up the duct work, then the upper section is permanently attached and crown ran around. I do it this way to make installation easy for everyone involved. Most of the contractors I work for love this. Attaching the upper section you need to be creative. Usually screws above the crown line, and offset plywood that locks the front of the two bodies together.
1/2/19       #4: sloped hood vent access ...
Chris H.
Website: http://www.csaw.com
Thought I'd jump in here to mention that several of our customers use Lamello Tenso or Clamex P-System connectors to install range hoods with removable panels, including beveled/tapered assemblies. The pic is from one of our customers who builds a square box-type assembly with Tenso connectors, but it's just to give you the idea. The front of the hood disassembles and can easily be put back together after servicing. Check out other posts here on WW and use "Lamello P-System" or "Lamello Zeta P2" to see what other shops have had to say about it.
View higher quality, full size image (3000 X 4000)
https://www.csaw.com/lamello/p-system/lamello-tenso-p-14/
1/7/19       #5: sloped hood vent access ...
Harold morantz
Here in Florida, and I am sure in rest of country; inspectors have to see the venting connections before giving hvac permits and we also make a removable section that will fit in seamlessly after inspection and can be removed for any repairs in future, for a flat hood, we use hinged doors, or the lamello or click clips, picture shows a real tricky one before u shaped panel was out in. This is a 15’ ceiling and a 9’hood! A monster to install!
1/8/19       #6: sloped hood vent access ...
Brett
Thanks for the responses everyone. We do as most of you do with the square hoods. Typically, the doors above will be hinged for easy access.
The angled hoods we will use hurricane or lamello clips to snap the panel on the face.
It looks like for the curved/sloped hoods most of you build them in 2 pcs. Right now we build them in one piece. We have never had the vent installer or inspector say anything about this(from Wisconsin). They can apparently get them hooked up somehow. However, it may come back to bite us one of these times so we may have to look at doing them in 2 pieces. I like how all the seams turn out when they are built and finished in one piece.
Thanks for the input.
1/15/19       #8: sloped hood vent access ...
Dan Member
Hi Brett,
As Chris H. mentioned in his response above, the Lamello P-System is a great solution for being able to build an access panel into your range hoods. Wisconsin has a great local resource for Lamello information in K&L Sales, they'd be able to come to your shop and give you a demonstration if you'd like.
