Bypass doors
2/27/20
Tony
Hey guys. I have an entertainment center to bid for a good previous customer of mine. The one they have found that we are trying to mimic has 3 doors. Two outside that move in the same track, and the center one is in a track behind. There is no visible hardware that I can see from the pics they sent-just two grooves. It appears from what I can see, that the doors must have a roller on the bottom that is hidden and rides in the grooves.
Just looking for suggestions for what is out there that you have used. They don't want to see a hardware track. Any help is appreciated. Thanks
View higher quality, full size image (480 X 360)
2/27/20       #2: Bypass doors ...
D Brown
if you wax the bottom edge of the doors they will slide without hardware.
2/27/20       #3: Bypass doors ...
Tom P
I recommend the EKU bypass hardware. Sold by Hafele. I recently used the EKU 16 for a project. Fast install, hidden track, simple adjustment reasonable price, and soft-close
2/27/20       #4: Bypass doors ...
You might want to look at this hardware I have used this many times
bypass door hardware
2/27/20       #5: Bypass doors ...
We have a kitchen coming up with some bypass doors.
I pinged my local Hettich rep to send me some stuff to try out. The hardware looks good, but I don't know about long term reliability.
I did a kitchen 7-8 years ago. I dado'd an aluminum U shaped track into the bottom deck and into a strip across the top. The doors had a strip of UHMW on the top and bottom. They worked well, and I'd assume they'd last virtually forever, but certainly not as slick as some soft close option.
It likely cost me a lot to build that too versus just buying hardware.
2/27/20       #6: Bypass doors ...
Stewart Member
Tony, can you take one of the doors off to see exactly what was used? I'm curious whether it would be rollers or some sort of a hard plastic guide strip. I've never liked having the track seen - whether it's been aluminum or plastic. If there is a smart way to keep it unpretentious and simple and still have it work well, I'd like to know what it is. I've used several different systems out there but it always comes back to my eye being drawn to the track - which is exactly what I am trying to hide.
3/2/20       #7: Bypass doors ...
Tony
I found these. They look interesting. I'm wondering if I can use without the track?
https://www.thehardwarehut.com/catalog-product.php?p_ref=294688
3/2/20       #8: Bypass doors ...
Tony
Couldn't get the link to copy, but I found these and they look interesting. I think it could even be used without the track?
search Rolle 2000 Trola
    • Impact Search and Placement
    • ECabinet Systems
    • Better Vacuum Cups, Inc.
    • Doucet Machineries Inc.
    • Forestry.com
