Finding older Grass
8/6/19
Rick G. Member
Website: http://rickgarnerfurniture.com
Hi all, need some help finding about 75 grass hinges, # on the hinge is 1800-63 no # on the mounting plate, but it mounts from side and rear. A few on e-bay. I know these are discontinued. Looking for a replacement! any Ideas??? Thanks, Rick.
8/7/19       #2: Finding older Grass ...
Rick,
This is Salice (Not Grass) but is this what you mean when you say they mount to the edge and back? If so, Salice has these readily available from any of our distributors.
Note: It is actually the hinge mounting plate that fastens to the edge and back. The "hinge" is any standard Salice hinge. The hinge then clips on to the mounting plate.
Good luck
Dennis
View higher quality, full size image (1797 X 2343)
8/7/19       #3: Finding older Grass ...
Rick G. Member
Thanks, Dennis. I will ck it out!
2/27/20       #5: Finding older Grass ...
shalom
i have it tex310-3914750
    • Impact Search and Placement
    • ECabinet Systems
    • Better Vacuum Cups, Inc.
    • Doucet Machineries Inc.
    • Forestry.com
