SCM Planer volt conversion 440v to 220v
2/27/20
Cian Member
I recently purchased a 2001 SCM S630 planer that originally ran on 220volts, it now runs on 440volts. I am looking to understand what is required to internally convert the machine back to running on 220volts.
2/27/20       #2: SCM Planer volt conversion 440v to ...
Something doesn't add up. What country are we talking about? Are you talking 3 phase? I thought it was 480.
2/28/20       #3: SCM Planer volt conversion 440v to ...
SteveL Member
I just went through the same thing with a SCM shaper. There was a diagram on the wiring box on the side of the motor, it made no sense to me so I had my electrician do it. He it wasn't really quick for him either.
I've had to do this on a few other machines and the diagram on the motor tag was easy for me to understand, not with this shaper.
2/28/20       #4: SCM Planer volt conversion 440v to ...
Cian Member
The planer was made in Italy, 440v is european.
SteveL, was the solution just moving the wiring around or also replacing parts?
2/28/20       #5: SCM Planer volt conversion 440v to ...
SteveL Member
for the shaper, yes, but he also adjusted the contactors too I think because the amperage increase.
On my planer I also had to change "heaters" which are like fuses but I don't know if that will apply to yours. I would give SCM a call and ask to talk to a service rep. you will most likely sit on hold for a while but might be of help.
2/28/20       #6: SCM Planer volt conversion 440v to ...
To my knowledge there are some woodworking machines that can be wired differently or changed to match the voltage power supply of your building. I believe the majority of machines are built or ordered for what ever voltage you have . If you decide to move or buy a used machine you need to get a transformer to install between your machine and your power source. You have to get the machine to match your voltages, they make one for every combination. Used ones I have seen sell for $25 and new ones can be in the thousands for big cnc’s and bigger equipment.
3/2/20       #7: SCM Planer volt conversion 440v to ...
mick steele
Cian, the motor wiring would need to be altered, inside the pecker head (thats where the wires go into the motor) there will be a diagram showing 440v wiring and 220v wiring, wires will be lettered or numbered. Going from 440 to 220 will increase amperage draw so fuses (heaters) and contactor should be checked for use of higher amp draw. Most contactors will have adjustable amp settings. Most 3 phase motors are dual voltage and as such you may find that the fuses and contactor are sized accordingly. The process is not difficult but I would suggest a industrial electrician do it if you are not sure. Regular commercial electricians do not always understand industrial wiring.
3/3/20       #8: SCM Planer volt conversion 440v to ...
randy Member
As Mic said, it's likely just a matter of switching the wiring in the peckerhead. Low & high voltage schematics should be on the peckerhead lid & if not, SCMI should be able to give it to you.
I had to rewire 6 motors on my weinig moulder. It was wired high voltage. Took all day between phone calls to weinig & texting pictures & phone calls with my buddy who was walking me through the process, but once I got my mind around it, it wasn't hard. The motors had either 6, 9 or 12 wires. I had to also change out all the breakers in the moulder because they were too light.
5/8/20       #9: SCM Planer volt conversion 440v to ...
Al Gerhart Member
Transformers aren't that expensive. I used to have a huge 36" cast iron double head planner that ran on 440 volts. I think I paid $1000 for a transformer about the size of a kitchen sink cabinet. No need to change the heaters if you run it on the voltage it was built to run on.
    • Texas Woodworking Festival
    • J&P Machines
    • Forestry.com
    • Better Vacuum Cups, Inc.
    • Laguna Tools
