Pass door hinge, sorta?
5/18/20
I have a client that wants a doorway to a laundry room, from the kitchen, look like a cabinet. It'll be a pair of doors. I don't want to use pass door hinges, and I don't want to use a cabinet hinge.
It hasn't been determined yet whether the door will swing into the cabinet or out into the room yet. If it swings in, I'd like to do something that is sets into the side of the cabinet and looks like wainscotting or similar when in the open position.
I looked at a Sugatsune hinge that is similar to a SOSS hinge, (HES3D-190), for another project a while back, but didn't go that route. They have a 180º swing, that shouldn't be necessary, but will be fine.
Good recommendations?
5/18/20       #2: Pass door hinge, sorta? ...
duster
I did this entry to a walk in pantry using 5 blum hinges per door. They were mounted to the jamb which I included. It was for an out of state job, clients contractor installed it. That was 10 years ago, no call backs...
View higher quality, full size image (600 X 800)
5/19/20       #3: Pass door hinge, sorta? ...
Michael Sanders Member
I've used Sugatsune and Tectus concealed passage door hinges. Both times I was doing hidden doors to closets under stairs, the doors swung out, and I used a push to open device in place of knobs. Both are very similar to SOSS but have 3D adjustment and are super sturdy. Could probably be adapted to work in your situation.
    • GreCon
    • WalzCraft
    • WOODWEB, Inc.
    • American Vision Cabinets
    • J&P Machines
    • O'Shea Lumber Company
      Merchants of Fine Woods
