Concealed hinge question
6/25/20
Pete
Don't have much experience with concealed hinges so I thought I would aske here after searching the web endlessly.
I have 4 doors, 67" tall, 20" wide, 1" thick, plus four 20" by 20" doors. Inset face frame construction. On the boxes- some of the face frames are flush to the box, the others vary. Im looking for concealed hinges for full inset doors that would swing 160. Any thoughts?
6/27/20       #2: Concealed hinge question ...
CGiles
My suggestion would be to build the cabinet to suit the hinge condition. A hinge that swings 160 degrees is going to be designed for a 3/4" door. So cut pockets in the back of the door deep enough to make it 3/4" where the hinges are. Build out the cabinet interior where the hinges are located, so you get the flush inset condition. Then build a small mock-up of this to make sure it will work. It only takes a few minutes, and will make sure you don't get any ugly surprises when you assemble.
7/8/20       #4: Concealed hinge question ...
jamien Member
CGiles comment about a mockup is key. i'm constantly bewildered buy the concealed hinge options. to simplify making the correct choice i have built small mockups of each new hinging situation with two hinges each to ensure the adjustments are enough and i have the centers in the correct place. write the manufacturer part number on the mockup for both hinge and plate. i've got nearly a dozen in a drawer now, but i no longer have to figure out a blum chart with each project. ordering with the part numbers right on the mockp is easy.
    • American Vision Cabinets
    • Salice America Inc.
    • American Fabric Filter Co.
    • INNERGY
