Blum Hinges
11/13/20
Gary Balcom
Just curious, has anyone else noticed that the Blum Inserta 120 full overlays aren't centered in their adjustment range lately?
I've been chasing an issue for a while now where the doors aren't aligned when hung. double-checked material thickness, checked our CNC programs and the tab distances, etc.
Then we noticed that you could only turn the adjustment 1/2 turn one way, but 2 turns the other way. I believe this is it. It's not "wrong", but does require us to adjust every door we put on. Curious what experience others have had out there.
11/14/20       #3: Blum Hinges ...
Roy Cameron
What size gables are you using? They seem to come set for 5/8 gables, I use 3/4 and find the same thing.
11/14/20       #4: Blum Hinges ...
Gary R Balcom
Roy,
That could be it exactly. I'm also using 3/4".
11/14/20       #6: Blum Hinges ...
They are set for 16mm. Euro kitchens are typically made from some laminate, veneer or higher quality melamine. Those are all 16mm. Not many 3/4” wood doors.
11/18/20       #7: Blum Hinges ...
Bruce H
We use 3/4" material, buy a 120 degree plus Blum hinge and rarely spend much time on adjustment. If you are using 5/8" end panels, don't buy a plus hinge. Two different hinges.
12/1/20       #8: Blum Hinges ...
Joe
We have a different drill pattern for 5/8 & 3/4
gables. 5/8 is about just shy of 1/8 from edge of door to cup. 3/4 is just shy of 1/4 . Seems to work perfect. Installer reminds me every time I forget.
    • American Fabric Filter Co.
    • WalzCraft
    • American Vision Cabinets
    • Impact Search and Placement
    • Biesse America
    • Template Services
    • J&P Machines
