cabinet door machinery
5/9/21
Ok I have read most of the posts on here about building cabinet doors. I was interested in why some of your suggestions on equipment is relevant. For example one person said they use five shapers, another person said they use three shapers. Why do you need 5 or why just 3.
I have been subbing out my doors , but recently the delivery has become very sporadic and also the quality has come down, and lastly the prices have increased, I know material has gone up, but seems even a increase a lot more than that.
I have done a lot of research, there are shapers, there are dedicated door machines, there are dedicated machines for stiles and rails like the unique machines and there are dedicated machines for the coping.
Which of these work the best and why?
5/10/21       #3: cabinet door machinery ...
Mark B
The multi-shaper issue is just one of how many operations work for you to break down between multiple machines, whether you run stacked tooling, left and right hand tooling, cope before or after sticking, edge profiling, and so on. Stacked tooling and shaker may get you down to a single machine, raised panel, left and right coping heads, sticking, and edge profile may have you in a battery of shapers all with fixed setups. It just depends on the work you do, space, needs, etc.. I have no experience with Unique style machines just shapers for doors.
It would seem pretty reasonable to quantify the amount of doors youre purchasing annually, how many different profiles and the cost of the tooling and machines, and go from there.
5/10/21       #4: cabinet door machinery ...
D Brown
In my one man shop I have run 5 shapers mostly to save on set up and have them always ready.If you forget a part or have a reject it is easy to go back.
Stile , rail, molding, raised panel, edge details.
5/11/21       #5: cabinet door machinery ...
I run 3 shapers, cope, stick and panel. Since I do mostly inset or small margin Euro most of my door edges are square.
I use brazed carbide cutters all from one maker and this allows the fence setup to be the same. Change over only requires the spindle to be raised or lowered. After you do the setup I use a digital height caliper setup and record it so I can refer to it when I need the cutter again. Currently I have 4 setups that can be changed out like this and one more that needs different fence alignments.
5/11/21       #6: cabinet door machinery ...
Jim Herron
I have five shapers.
The last several years only running mostly two, with everything being flat panel and square outside edge profile.
I have four profiles of freeborn insert tooling for cope and stick, and never adjust a spindle or fence, just change heads and keep rolling.
My raised panel cutters and arch templates haven't been off the shelf in years.
If you do decide to go forward I'd take a hard look at Weaver shapers( I bought mine used) and insert tooling with common minor diameters and height to reduce setup times.
5/16/21       #7: cabinet door machinery ...
cabinetmaker
Sold off 4 shapers when we started down the path of commercial work.
We run a panel raiser on a shaper and router bits on 2 dedicated router tables. A 3rd is used for profiling.
Topcoat the heck out of fences and tables.
We work like crazy to get a real good flat tight joint off the face reducing sanding time.
I agree with others on all set up tables/shapers makes for fast work
5/26/21       #8: cabinet door machinery ...
Doug Conti
I use a unique 250 door machine, with insert tooling. The only draw back is when the doors are over 42 " tall I have to them on a shaper. I leave one shaper set up for that and just switch the heads. It has a small footprint does a good job. I have been making all my doors for years this way everything from shaker to arch raised panels Out sourcing doors is too expensive, you can make money on doors plus if one does not fit or a cabinet is added you can have your doors that afternoon.
    • Impact Search and Placement
    • ECabinet Systems
    • Better Vacuum Cups, Inc.
    • Doucet Machineries Inc.
    • Forestry.com
