Concrete Countertops
1/7/19
Danny Brown
Website: http://www.fortsmithconcrete.com
We are a concrete company and get calls from time to time for concrete countertop fabrication. We really do not deal with volumes that small. Can a call like that be referred to a cabinet maker who might be able to fill that order?
1/8/19       #2: Concrete Countertops ...
MarkB Member
We do concrete tops on occasion but they are something I would guess any sane minded shop would shy away from unless they have a pretty hefty chunk of real estate in thier shop to set aside. Its a horrifically messy process whether you are running full thickness on a vibrating table or shooting GFRC. Either way its a mess, it requires a good bit of dedicated space and equipment to be able to be profitable, and when you really get down to it (especially with GFRC) by the time you add up all the materials, form material, additives, and the fact that your customer has to be willing to accept what comes out of the mold (they will never be able to see EXACTLY what they will get) it can be a tricky endeavor.
In our area most that contact us with regards to concrete tops do so thinking its almost a DIY job and expect it to be a lot cheaper than solid surface, granite, marble, etc.. When they see those numbers surpass post formed laminate at the home center the phone usually goes dead on the other end.
6/10/21       #3: Concrete Countertops ...
Shane
Website: https://www.riverside1movers.com/
Get in touch with our company, and it will be an easy and smooth move. As the best Riverside mover service providers, we are fully equipped to offer a wide range of services. Here are some of the moving services you can book. Our online platform is easy to use, you can book an appointment with us anytime, and we will respond fast to offer you the top moving solutions.
    • Texas Woodworking Festival
    • J&P Machines
    • Forestry.com
    • Better Vacuum Cups, Inc.
    • Laguna Tools
