Front frameless sinkbase for Kohler cast iron farmhouse sink
9/4/21
Gene Davis
I tried for a good thread title, but it's not easy.
Would like to do a tight-fit arrangement in frameless for the Kohler sink, but want best way to design sides-stretcher-apron joinery.
It's all about that cutout that's done for the sink.
Does this become the ONLY cab in the whole kitchen that's faceframed, because of where that cut needs to be?
9/4/21       #2: Front frameless sinkbase for Kohler ...
Cut it into a false drawer front.
9/4/21       #3: Front frameless sinkbase for Kohler ...
MB
I like to make the cabinet frameless with a shelf for the sink, and then attach a 3/4" thick piece next to the sink and above the doors, which can be cut to whatever size and shape the sink requires.
9/4/21       #4: Front frameless sinkbase for Kohler ...
Gene Davis
Well, it's looking as if I can put a stretcher with a finished outboard face across the front, 4" high, and the sink is such that the clearance will be there for the stretcher to reach up in the space between bowl and apron.
At 4", we can do a lock tenon joint and zipscrew this thing in and give nice bracing to the cab sides. The sink glues down onto 2x4 framing that is screwed into the cabinet insides, and the whole thing will be battleship-tight.
Thanks for looking and commenting, and thanks to Kohler for providing accurate 3D for this product, downloadable as a Sketchup file.
View higher quality, full size image (696 X 743)
9/4/21       #5: Front frameless sinkbase for Kohler ...
Mark B
I hate to sound like a purist but does "farmhouse sink" and "frameless" make anyone else snicker an laugh inside? So unbelievably odd... But, full agreement, take the cash and make what they want.
9/4/21       #6: Front frameless sinkbase for Kohler ...
Face frame surrounding the sink which would be level with the doors below it.
9/5/21       #7: Front frameless sinkbase for Kohler ...
Adam Spees
I'm a face frame guy, unless someone needs something within a house I'm already working on.
I thought with frameless you simply build a short lower cabinet and the farm sink sits on top of it. Obviously you build some structure to support it as the manufacturer specs.
I'm thinking of it like an appliance except you give it a few mm of room to get it into the opening. So the adjacent cabinet doors have their typical gap up against the sink.
I plead ignorance on this one.
9/5/21       #9: Front frameless sinkbase for Kohler ...
MB
Mark B - "Apron sink" .... very contemporary :)
9/5/21       #10: Front frameless sinkbase for Kohler ...
Gene Davis
I think we'll widen the cabinet and bring the sink out 13/16" so it's surround is a false drawerfront. Like this.
View higher quality, full size image (1202 X 800)
9/7/21       #11: Front frameless sinkbase for Kohler ...
Bruce H
I do these often enough to have come up with simple construction that works with my frame-less construction. I make a short cabinet that the sink sits on with a top rail that the doors will close on. I make it wide enough so there is clearance under the sink. Some sinks have a lip down and others are flush. There is an appliance trim on each side, or in this case a dishwasher cabinet on the right.
View higher quality, full size image (3394 X 1863)
    • American Vision Cabinets
    • TradeJobPlacement.com
    • Forestry.com
    • Biesse America
    • Doucet Machineries Inc.
    • Better Vacuum Cups, Inc.
