Thermwood assembly marks: helpful? Best practice?
9/25/21
Gene Davis
Are they a worthwhile aid? Does the extra time taken at the router pay off?
The designer can control which joints get the marks, so they can be on as few or as many as decided and programmed.
What's been your experience with these?
9/27/21       #2: Thermwood assembly marks: helpful? ...
Derrek
Don’t use thermwood but we have been marking our backs that we nest forever. We drill a 5mm hole at top edge that gets 1/2 of it cut off when part is cut out. The rest of our parts can only assemble 1 way. The visual control of being able to look at something and know exactly where and how it goes is well worth it
9/29/21       #3: Thermwood assembly marks: helpful? ...
Brad McIntosh  Member
Website: cncautomation.com
The a good majority of our Thermwood customers in Canada are using melamine and veneer with particleboard core. The "assembly mark" process that uses the side of the tenons does not register well in that material.
I would suggest that you perhaps also make your inquiry on the Thermwood forums (both "eCabinet Systems Software" and "Thermwood 3-Axis Machinery"), as you may get a more qualified response from Thermwood users that use the process with their plywood boxes.
Good luck!
9/30/21       #4: Thermwood assembly marks: helpful? ...
cabinetmaker
we don't have a thermwood, but use them
use every bit of the time on the router to designate assembly, banding, etc
definitely worth it
    • American Fabric Filter Co.
    • WalzCraft
    • American Vision Cabinets
    • Impact Search and Placement
    • Biesse America
    • Template Services
    • J&P Machines
