KV 8092 pocket door hdw
10/29/21
Tony
I have a situation where I need a 30" wide pocket door on a laundry cabinet. The hardware specs for the KV8092 say max hgt 42", max width 26". But in looking at the drawing for the 30" set, it looks like 26" is just the max that is recessed in the case. Am I right in thinking I can use a 30" door and just let it protrude the extra 4"? I know that is typical of the 8080/8070, and the customer is fine with the extra protrusion, I just can't see any info if that will cause any unforeseen problems or not. Thanks
10/29/21       #2: KV 8092 pocket door hdw ...
Thomas Gardiner
You made a typo in the specs. The max height on the spec sheet is actually 72". So I think the weight of a 30" wide door wouldn't be an issue.
10/29/21       #3: KV 8092 pocket door hdw ...
Tony
Thomas-thanks for responding. I'm not so much worried about the weight as the width and depth when retracted into the case. They say max door width of 26", then the dimension sheet has a 30" slide that specifies the door retracts 26". I'm wondering if there are any other issues with using a wider door (wider than 26") other than that it won't retract further than 26" and the rest protrude. Which the customer and I both are fine with.
10/30/21       #4: KV 8092 pocket door hdw ...
james e mcgrew  Member
There needs an allowance for the hinge truck hardware when figuring the total that allowand is shown on 4.12 page 5 of install instructions and is like 4" so per chart 1 a 30" door on a 30" cabinet will protude 4"
We have installed a buukoo of these and it is a great set of hardware. one of the guys just used them to make a hidden door to a wine room in a paneled hallway.
    • American Vision Cabinets
    • TradeJobPlacement.com
    • Forestry.com
    • Biesse America
    • Doucet Machineries Inc.
    • Better Vacuum Cups, Inc.
