Cabinet installation to replace water damaged cabinets
11/27/21
Looking for ideas to make the process more efficient
Last customer described this as building a ship in a bottle as the counter tops and some of the cabinets were still intact.
I build new cabinets and slide them into place and use bolts and tee nuts to raise the cabinet under countertops
Thought about the leg levelers but wasn't sure how to put them on the cabinet it was under counter
TIA
11/27/21       #2: Cabinet installation to replace wat ...
Thomas Gardiner
There are leveling feet with a large (8 or 10mm) threaded hole in the centre that you can drive a mounting screw down from inside the cabinet. Richelieu would have them. Not a fan of holes in the cabinet floors but I think they come with plastic caps.
Or you can use the euro feet to get the cabinet in place then construct a kick. piece by piece, under the cabinet
11/27/21       #3: Cabinet installation to replace wat ...
Thanks Thomas
Do you know the model number of that leg leveler?
11/27/21       #4: Cabinet installation to replace wat ...
Thomas Gardiner
Here is the cabinet mounting puck:
Richelieu # 8410090
The legs and bolts can be purchased separately.
11/27/21       #5: Cabinet installation to replace wat ...
Thanks Thomas I will try those
11/30/21       #6: Cabinet installation to replace wat ...
Derrek
Hafele has the new leveler I believe they are Axilio. They have a large base leg that a special tool fits on to adjust height. . We are switching over to them.
11/30/21       #7: Cabinet installation to replace wat ...
Thanks Derrek
What would the advantage be over the Richelieu # 8410090?
11/30/21       #8: Cabinet installation to replace wat ...
Derrek
Side by side comparison to old style vs Axilo
https://youtu.be/-TfbMA0pWV0
11/30/21       #9: Cabinet installation to replace wat ...
LOL thanks that is a great video
This is a picture of how i raise the cabinets once there under the counter
I would like to be able to adjust the feet from the top of the cabinet so i can use the same hole i have for the tee nuts
View higher quality, full size image (4160 X 3120)
12/2/21       #10: Cabinet installation to replace wat ...
Kevin Dunphy
Website: http://www.kdunphy.com/
The level system looks like it belongs in the same tool box as the pocket screw jig .
The thing is there has to be a basic understanding of my goals when I install , the base need to be screwed to the floor that's a lot of weight with the draws opening.
Ladder is the way to go slide the base screw it in ,slide cabinet doesn't get easier than that .
Here a link of a video of a ladder base I installed
https://www.youtube.com/watch?v=UCW9trTickI&t=530s
12/10/21       #11: Cabinet installation to replace wat ...
Bruce H
Trying to jack cabinets up when the counters are in place isn't always that easy. These levers might work better than the foot system. The cost could be justified based on trying to save what is existing.
https://www.youtube.com/watch?v=6H5IhNV8O5I
12/10/21       #12: Cabinet installation to replace wat ...
Thanks Bruce
Not sure that would work, I would need an inch of adjustment to get under the counter then raise the cabinet up
    • Texas Woodworking Festival
    • J&P Machines
    • Forestry.com
    • Better Vacuum Cups, Inc.
    • Laguna Tools
