Casadei K320 not heating
12/21/21
Sam Scowen
I just got the casadei k320
Good condition but, the glue pot has been sitting at 16° for over an hr now. I don’t understand why.
1- the emergency switch is not enabled
2- the belt feed is closed and locked
Can anyone assist me with this issue?
12/22/21       #2: Casadei K320 not heating ...
Tom Gafgen
We just had the same problem yesterday with our casedei bander . Turns out we had 1 blown fuse in our wall mounted fused 3 phase disconnect so we were only getting 2 phases of elect. and that would run the control panel but would not run the heating elements .So I would verify that you are getting all 3 phases of elect to the machine.
12/22/21       #3: Casadei K320 not heating ...
james e mcgrew  Member
You can also turn off all power and disconect on side of element then check for continuity, a pot needs all its elements to heat up less elments working will cause this
12/22/21       #4: Casadei K320 not heating ...
Sam Scowen Member
So manually I can switch the pot on using the internal control switch but it took almost an hr to get to 90°. So today I changed it out with a spare control switch and same issue. Had to manually turn it on and still warmed a slow rate.
12/23/21       #5: Casadei K320 not heating ...
Tom Gafgen
There are several heating elements in that pot perhaps one or more of them is bad or has a bad connection
12/23/21       #6: Casadei K320 not heating ...
Tom Gafgen
Also make sure this switch is turned to the right where I have the arrow drawn
12/23/21       #7: Casadei K320 not heating ...
Sam Scowen Member
How do I go about checking the elements?
12/23/21       #8: Casadei K320 not heating ...
Sam Scowen Member
12/23/21       #10: Casadei K320 not heating ...
Tom Gafgen
Google testing heating element with a multi meter, however you most likely need to dismantle the glue pot to do it and that appears to be quite a task.
12/23/21       #12: Casadei K320 not heating ...
Sam Scowen Member
Ok this is going to be fun. I’ll start with the fuses, breakers, control switches and see what I can find out. Appreciate everyone’s input thanks! Will update soon. Maybe we we all learn something 🤷🏻‍♂️
12/24/21       #13: Casadei K320 not heating ...
Ed
Hello, I had the same problem with an scm machine , my tech walked me through some fixes over the phone . My machine has a row of trap door fuse compartments , one was bad . Home depot and Grainger had the replacement fuse.
Ed
12/24/21       #14: Casadei K320 not heating ...
Sam Scowen Member
UPDATE: I have tested everything and the only unusual thing I have come across is the elements are only receiving 90V but I can’t determine if that’s right or not. I have included a photo, maybe some can give me an idea where to go next?
12/24/21       #15: Casadei K320 not heating ...
Sam Scowen Member
Hi Ed, I checked all the fuses and they are A ok. Unfortunately I was praying for an easy fix but no such luck.
12/24/21       #16: Casadei K320 not heating ...
Sam Scowen Member
12/25/21       #17: Casadei K320 not heating ...
Chip Geffre
Hello Sam-Every time I had issues with my gluepot not reaching temperature, it was bad heater cartridges. A gluepot will generally have 3 or 4 of these heaters.
You may be able to use an infrared thermal tester to find the cool spot on your gluepot. (About $15 at Home Depot or Amazon. This would likely reflect which heater is not working. Each cartridge has two wires coming from it.
disconnect the wires from a suspected bad heater and check continuity with a circuit tester. If the heater is bad, it will show as an open circuit. Most of these heaters are in the shape of a large pencil, usually held in the pot casting with a set screw, and are easily removable, some are in the form of a plate on the bottom of the gluepot. My Cehisa bander had both. Here is a picture of a typical "pencil rod heater cartridge".
https://https://www.amazon.com/dp/B0148O64JE?aaxitk=bf9a858cf182db1577b10a1d24bae600&pd_rd_w=LZJSt&pf_rd_p=81374be5-e348-4c15-938f-a311a861c514&pf_rd_r=G4E9799BPMV43BAFJ07X&pd_rd_r=e16a398a-08cf-4ac6-a8b1-b05ca7018927&pd_rd_wg=bBxA8&ref=dacx_dp_591644178274974384_591789597521277347
12/25/21       #18: Casadei K320 not heating ...
Chip Geffre
Sorry, picture didn't upload. Here you go!
View larger image
12/25/21       #19: Casadei K320 not heating ...
Chip Geffre
Sorry, I am a bit challenged with posting an image. I will keep trying to post a picture of a typical heater.
View larger image
12/28/21       #20: Casadei K320 not heating ...
Sam Scowen Member
So turns out my 90v was a false read, the elements are receiving 130v and after checking each element they are all good to go, so all the elements are fine. Im so lost as to what the problem is. I had an electrician by yesterday and he said all the electrical components are working and have no damage. He was sure it was the elements but they all read the same 241 ohms and one smaller element at 170 ohms.
I also checked the emergency stop button and the safety switch on the belt arm. They are functioning like they should.
Really appreciate your help here got anymore ideas?
12/28/21       #21: Casadei K320 not heating ...
Sam Scowen Member
Manual if anyone is interested
CASADEI_INDUSTRIA_K_320___WOOD_TEC_PEDIA.pdf
12/28/21       #22: Casadei K320 not heating ...
Sam Scowen Member
Sorry wrong file! This is the manual
K_320_072004_ITA_ENG_FRA.pdf
    • Better Vacuum Cups, Inc.
    • Biesse America
    • CP Adhesives
    • Impact Search and Placement
    • Template Services
