Hafele convoy Centro soft closing issue?
9/11/22
Drum maker Member
I have installed a Hafele convoy Centro the cabinet is square and level, everything in the installation manual has been followed and is understood.
When I try to open the slide there is a slight resistance and when I try and close it I get a resistance at about where the soft close should take over I then have to push the door to get it to close?
There isn't any information I can find that relates to this fault, has anyone else had this problem?
Cheers
9/23/22       #3: Hafele convoy Centro soft closing i ...
Scott in NC
Did you contact Hafele or Kessebohmer?
9/25/22       #4: Hafele convoy Centro soft closing i ...
Drum maker Member
No Scott I didn't, I figured if the information wasn't on the instructions or the Youtube video's didn't mention it then I guess it is what it is.
