Variability in thickness of UV2
10/25/22
Dave
How are others contending with the variability of plywood thickness as it relates to ordering drawer boxes when using Cabinet software (Mozaik). I sometimes need to order drawer boxes before I even have the plywood in the shop and this week I can't get any domestic UV2 and so am having to go with import. I have seen a range of almost 1/16" of difference in thickness between domestic and import. Is there enough tolerance in undermount slides to compensate for that, or should I not order drawer boxes until I can measure the ply thickness?
10/25/22       #2: Variability in thickness of UV2 ...
Are you seeing consistency issues with using the same panel over and over?
Like in a unit are you seeing that? Or unit to unit are you seeing a big discrepancy?
If you're going from one manufacturer to another, I'm not surprised. Even buying what should be the same panel from two different suppliers will get you different results as well.
I do find entertainment in a panel measuring .716, that it counts as ¾".....
10/26/22       #3: Variability in thickness of UV2 ...
david zaret Member
this is why i use Garnica UV2. it's consistent - apparently the core is sanded to a uniform thickness before veneering. i don't see any substantial variation from sheet to sheet.
i used to use Columbia maple UV2, but the 0.030"+ variation throughout a bunk killed me on the CNC, so i switched to Garnica.
-- dz
