Cabinet door press
3/25/23
Brian A Franco Member
Website: http://iwswoodworking.com
I am looking to see what type of clamping methods other shops are using to clamp cabinet doors. Currently, we are using bar clamps but this is taking far too long. Looking into a J.L.T. pneumatic cabinet door clamp but gluing 1 door at a time doesn't appear to save any time. Any thoughts would be greatly appreciated.
Brian
3/25/23       #2: Cabinet door press ...
perley
I use that clamp. Glue one and put in clamp. Then glue another. The first has set enough that you can take it out of the clamp. Al so you could pin the joint. I don't pin mine. Never had a problem.
3/25/23       #3: Cabinet door press ...
Bruce H
I have JLT clamp, its not all that fast however it is convenient. Sometimes we have doors that need a bit longer clamp time, using space balls with a raised panel would be an example of that. In that case we use a bar clamp after it comes out of the JLT clamp. I don't pin my door joint.
3/26/23       #4: Cabinet door press ...
I use a rotary JLT door clamp, and pin them yet.
3/26/23       #5: Cabinet door press ...
Chippy1987 Member
I use a JLT clamp for projects in the shed. Not a particularly quick process but very handy.
3/28/23       #6: Cabinet door press ...
duster
We use a JLT panel clamp. It has 18 clamps, so we can clamp up to 9 doors at a time. By the time we've glued up 5 or 6 doors, they're dry enough to remove and cycle through the next batch.
4/3/23       #8: Cabinet door press ...
KenW
JLT rotary clamp, 3m PUR adhesive, no pinning, approx assembly time is 45-60 secs per door. Been using this method for 12 years, not a single door failure.
4/3/23       #9: Cabinet door press ...
Jim Herron Member
JLT double door clamp, titebond 1, 8 panel buddies oer door, and two 23ga pins per joint
Goes fairly quick and holds good if you rack them with reasonable care
    • Better Vacuum Cups, Inc.
    • Biesse America
    • CP Adhesives
    • Impact Search and Placement
    • Template Services
