Shaker doors
12/16/23
Darrell morgan Member
Does anybody build shaker doors with soft maple tounge and groove joints and 1/4 inch birch on MDF flat panel for center panel and use Bondo in the joints to hide the hair line joints
12/16/23       #2: Shaker doors ...
Nope. Never had any issues that would require Bondo in the cope and stick joint and I would never put 1/4" hardwood on MDF. 1/4" is too thick to be called veneer and acts like hardwood. Expect lots of trouble with seasonal wood movement if you insist on doing that.
12/17/23       #3: Shaker doors ...
No I meant I use a 1/4 inch MDF panel with birch veneer on both sides
12/17/23       #4: Shaker doors ...
If I did that I would probably use a maple on MDF panel, not birch. No need to use bondo in the joints if they are milled correctly. And using bondo in the joints suggests to me that it is a paint grade product and I would be using a 3/8" MDF panel with no veneer.
12/17/23       #5: Shaker doors ...
Yavuz Member
Darrell ,
Mdf or Plywood core is totally acceptable.
Mdf also is stable and good choice IMHO. Just do not use any caulking on the inner edges.Tack 23 gauge on for side edges and let the solid wood parts moves seasonally.
12/20/23       #6: Shaker doors ...
Ken Member
How does the seasonal wood movement impact a painted door? I'm concerned I'll get to much movement from the 1/4 panel which will expose the unpainted wood.
12/22/23       #7: Shaker doors ...
I use 1/4 panels in Minnesota. They move less than anything else does I think.
12/24/23       #8: Shaker doors ...
Just to clear up ,the material I'm using for the shaker doors,is 2 1/2 wide popular stiles and rails with 1/4 inch birch on MDF center panels,I have a customer that does not like one piece MDF doors and D-fronts,she wants real wood frames.if I had my choice it would be the 3/4 one piece cnc routed all MDF shaker.
12/24/23       #9: Shaker doors ...
Soft maple over Poplar
    • Better Vacuum Cups, Inc.
    • Texas Woodworking Festival
    • American Fabric Filter Co.
    • Denray Machine
    • Template Services
