Computer Aided Design
Subject: Re: Cabinet vision dovetail boxes
8/6/13
Bob Member
I trying to set tools for dovetail drawers but somehow Cabinet vision pick 3/8 DOWN SHEAR
Any idea what I doing wrong?
View higher quality, full size image (512 X 588)
R810301N.pdf
8/6/13       #2: Cabinet vision dovetail boxes ...
Adam B  Member
Boban,
If you look in the right side there are a few locations where it has what bit to use and there is not one chosen.
Click on the box that says N/A and then you can choose the correct bit.
8/7/13       #3: Cabinet vision dovetail boxes ...
Bob Member
I will try
Any idea what to select ?
8/7/13       #4: Cabinet vision dovetail boxes ...
Adam B  Member
For "F" Rabbet Tool you will probably want 3/8" or 1/2". You will also want to use the same tool for "H" Pocket Tool.
8/7/13       #5: Cabinet vision dovetail boxes ...
Bob Member
Ready try not luck
that is what is generate to G code ;
M92
(ROUTE TOOL #14: 3/8 DOWN SHEAR)
(DIAMETER: 9.525)
8/7/13       #6: Cabinet vision dovetail boxes ...
Adam B  Member
You also need to put in an amount of 1" at the Nested Part Clearance then try running a couple of parts.
8/8/13       #7: Cabinet vision dovetail boxes ...
Bob Member
When I select Dovetail 1/2 COMP tool
I have message that rabbet tool exceed female plunge depth ?
Any idea ?
picture attached
8/8/13       #8: Cabinet vision dovetail boxes ...
Bob Member
I take picture of test piece
this is how looks like
8/8/13       #9: Cabinet vision dovetail boxes ...
Adam B  Member
It is using the dovetail bit to cut the rabbet.
You need to choose either the 3/8" or 1/2" bit to make the rabbet.
8/8/13       #10: Cabinet vision dovetail boxes ...
Adam B  Member
You also need to go into the drawer construction wizard and make sure to go through the Dovetail section and make sure you have the Dovetail bit selected for Std #084.
1/7/15       #11: Cabinet vision dovetail boxes ...
Simon Member
Sorry to hijack this thread, but I can't for the life of me find that dovetail bit with the rounded upper corners. Can anyone kindly tell me how and where to get those?
1/7/15       #12: Cabinet vision dovetail boxes ...
Adam B  Member
http://www.cncsolutions.com/product/dove-tool/
1/7/15       #13: Cabinet vision dovetail boxes ...
Simon Member
Awesome. Thank you!!
1/8/15       #14: Cabinet vision dovetail boxes ...
Kerry Fullington
Simon,
Here is a link to the Vortex bits.
Vortex Dovetail System
1/8/15       #15: Cabinet vision dovetail boxes ...
Simon Member
Wow. Those seem pretty serious. What is the benefit of the Vortex system? Any idea on blade replacement cost?
Thanks for the help!
1/8/15       #16: Cabinet vision dovetail boxes ...
Kerry Fullington
Simon,
I think the only advantage would be the insert cutters if you were cutting a great deal of drawers. The inserts are $37 on the Vortex site. I think you could find them cheaper.
We rarely cut dovetail drawers and use bits purchased through Thermwood.
Thermwood Dovetail Bits
