Computer Aided Design
Subject: Re: editing in Mozaik
editing in Mozaik
11/12/15
Jonathan Mahnken
does anyone know how to make end divisions flush with the inside edge of a faceframe so that drawer hardware can be mounted. I can do this to an added partition but not an end division
11/12/15       #2: editing in Mozaik ...
Jason Scott
Go the shape tab in the product editor.
Select the side of the cabinet you want to modify and then change the end type change it to unfinished end or finished end. Then you can set the scribe to the outside of the cabinet.
11/13/15       #3: editing in Mozaik ...
Jonathan Mahnken
thanks jason. worked perfectly. do you know how to combine cutlists on to the same page so I dont have to print out 9 pages for two cabinets
11/14/15       #4: editing in Mozaik ...
Jason Scott
You can select all parts for a chosen material. I would guess that you are selecting your cut list by part type (drawers,face frames, etc).
For 2 cabinets you can go to print dxf/assemblies and print cabinets. Remember to click the box for print assembly info. That is also the fastest way to print out your 2-d drawings.
Also if you get a CNC you will print at least one sheet of paper for every single sheet of material you cut. I am finishing a job that between customer paperwork, revisions, shop drawings, and the cnc cutsheets we will have gone through at least 250 sheets of paper.
