Computer Aided Design
Subject: Re: Old CV on Win 7 (help with one problem)
12/4/15
Brian VT
Ver. 3.5, Build 271
Everything works fine (in XP sp2 compatibilty mode) except the Door Catalog Editor. Actually...it works fine after a clean install...once. Then it locks up so CTL/ALT/DEL.
Open again and it asks to select DOOR.DDB or STOCK.DDB
Select DOOR.DDB and it just closes the Door Catalog Editor.
I don't know why it's asking which .ddb because if I look in the registry it shows DOOR.DDB as the default path.
Other catalog editors in Setup Kit work fine. Door Catalog Editor locks up no matter where I access it from.
Any ideas appreciated.
12/4/15       #2: Old CV on Win 7 (help with one prob ...
Brian VT
I had a similar problem on a slightly older laptop. Also Win 7.
For some reason I made a copy of DOOR.DDB and named it COPY.DDB.
It worked! I don't know why, and it's not working on this new computer.
12/7/15       #3: Old CV on Win 7 (help with one prob ...
Brian VT
More info:
If I go into the registry and change the default database then I can open the door catalog. All the buttons and tabs there work fine except Select A Door Style. If I click on that one button then the program locks up. The only way I can get the door catalog to open again is go back into the registry and change the default database.
What is up with this one button "Select A Door Style" ?
I can provide screen shots of the registry if that might help. There are some other lines in there that might be relevant but I'm hesitant to mess with them.
