Computer Aided Design
Subject: Re: Microvellum products disappeared
12/18/15
Dan Member
I have a problem with Microvellum. I have used the version of Toolbox7.
I created the project months ago and I haven't opened up for awhile. When I reopened it to edit it, all the 3D products that I created was invisible, but only 2D drawing in CAD is shown. However, the products and program is still existed in "Single Part Editor", which I could edit each piece by piece, but I cannot edit with "Product Prompts", neither "Part Property" tools.
I tried to do "Redraw from Database" tool at "Single Part Editor", but still the products are not appearing.
Does anyone had the same issue like mine and know how to resolve this issue?
2/13/16       #2: Microvellum products disappeared ...
Gary B.
Dan,
You'll need to see if you can find the products in overdrive Pro. If you can, that you'll be ok. If not, then somehow they were deleted. Also, if you have a 2D drawing of the PRODUCT (not parts), try the redraw button by clicking directly on the 2d item label (cabinet number with the rectangle) and choose draw 3d with full machining. hope this helps.
