Computer Aided Design
Subject: Re: Trouble Importing DXF's to Mozaik
11/24/20
Ryan Member
I'm working with a friend to make a christmas gift for her Neice, (URL below) and having some trouble getting the parts to load into Mozaik properly.
As of now I have tried making sure the DXF is a polyline, importing only one part at a time into the optimizer (which seems to be the only way to get individual parts into Mozaik without custom drawing them.
Is there another piece of software that someone might suggest that could help bridge the gap between AutoCad and Mozaik?
Has anyone had any success in using AutoCad drawn parts in Mozaik at all?
Unicorn Bookshelf
11/25/20       #2: Trouble Importing DXF's to Mozaik ...
james e mcgrew  Member
The file imports as MM not inches, I will try later to convert using Vectric and reexport to see if this is the problem
11/25/20       #3: Trouble Importing DXF's to Mozaik ...
Peter Matos
I have struggled with this as well. For one the editor in mozaik is kinda confusing so you think OK I will just draw it in CAD and then import it. Then you realize its not that simple. You do have to have a full closed polyline on the parts, I also found that purging the autocad file and removing any paper space pages from the file seemed to help. Also ensure there is no underlying geometry from your initial creation. I usually just grab the whole drawing and move it over. Underlying geometry will remain and you can just delete it etc. Having said all of this I still had issues importing certian drawings and am not entirely sure why. There are a few postings on their closed forum describing the issues but I never found anything that really seemed to isolate the problem. Their tech support seems to think it is not really their issue but they did try to help when I ran into problems. Good luck.
Pete
11/26/20       #4: Trouble Importing DXF's to Mozaik ...
Mark R Member
Into ACAD2014 and scaled down (as mentioned above), I hit OVERKILL to see if there were duplicated or overlapping points. At a tolerance of .001, the object at the lower left was very clean - only 1 deletion (probably start&stop), whereas the object third from the bottom showed 79 deletions. That can't be helpful and I didn't try any others. For a trial run I would take the first object, run the OVERKILL command and then save it out as a single object. That option is available in the Save As window. Tools dropdown - Options > DXF Options > Select objects. That way you're not carrying any other drawing information, just the geometry. My experience is that '04 travels nicely between applications.
    • INNERGY
    • Cabinet Pro
    • ECabinet Systems
