Computer Aided Design
running material over 97" long
9/17/13
Russell Brown
I always run 4 x 8 sheets on my Biesse Rover, but i need to run longer material, what do i need to do to tell the CABINET VISION program to allow me to use material over 97"?
i am using CV 4.2
my Biesse has a 50 x150 flat table
9/17/13       #2: running material over 97" long ...
Cabinetmaker
Fastest and easiest is to go into the material catalogue bc copy th most common sheet/panel you use. Rename it, change the length. Go into the new job and change the cabinet material schedule to the new one just created. Run screen to machine and check it out.
9/17/13       #3: running material over 97" long ...
Dave Roskilly
Check you limitations in the machine catalog also
The max X needs to be longer than the sheet you intend to run......
9/18/13       #4: running material over 97" long ...
Russell Brown Member
thank you, i did add it as a new material and eventually it worked, i just need to manipulate it to apply it to an existing job.
