Computer Aided Design
Microvellum Question
10/9/13
Matt
Have two questions for microvellum users out there. I try to use the mirror product command and all it does is copy the part does not mirror anything. Any ideas about this?
Also Is there anyway to bring back a subassembly after it is exploded?
Thanks for answers in advance,
10/10/13       #2: Microvellum Question ...
Scott R Smith  Member
Website: http://www.caseworkcadcam.com/
(1) I doubt you'll find this in the help file, but the mirror product command is for drawing in 2-D. When drawing submittals in 2-D the mirror product command is quite hand when you have opposite hand rooms, but in 3-D it flat doesn't work.
(2) When you explode a sub assembly and export it to the spread sheet you'll notice that all the part have been brought into the CutParts tab. So the only way I know that bring back the sub assembly is to delete the parts that were brought into the CutParts tab and then use the Show Subassembly list, in the Subassembies tab to add the sub assembly back to the product. Note you can also achieve the method I just mentioned using Product Properties on a 3-D product in a drawing.
Hope this helps,
10/10/13       #3: Microvellum Question ...
Lenny
You can delete the subassembly cut file in your job/subassembly folder and the program will bring in a new one from the template
