Computer Aided Design
Drawer slide screw locations
10/22/13
I want to set up some slides in my hardware catalog in Microvellum. We generally use Accuride slides but sometimes get KV8400 or some other cheap knock off that is not in my library. I was wondering if anyone has a good reference, or chart with screw hole locations from the front of a frameless cabinet for some of these. BTW, our assemblers use wood screws and not euroscrews for mounting cabinet members. I would like to get this automated for the cnc. Thanks.
11/6/13       #2: Drawer slide screw locations ...
John Ewer  Member
Website: ducabinetry.com
Look to the supplier they have charts in there catalog or the web
11/6/13       #3: Drawer slide screw locations ...
The problem was, the pdf on the web that I found was unreadable for some reason, even when zooming in. I had to wait for the slides to arrive before getting the hole locations, but thanks for the help.
11/19/13       #4: Drawer slide screw locations ...
I've found that by raising the Blum pattern mounting holes 1mm most offshore undermount slides will fit.
For wood screws I use a drill point drill and go 0.125 deep.
