Computer Aided Design
Cabinet vision tool operation
4/28/14
Bob Member
I trying to make 45 degree cut on CNC but cabinet vision keeping to pick straight bit
Any idea how I make that Cabinet vision pick 45 degree bit and cut?
4/28/14       #2: Cabinet vision tool operation ...
Jonah Coleman
It selects the bit for an operation you added, or for the outline tool? It won't automatically pick a shaped bit, you'll need to either add an operation to that edge, specify the tool #, and add extra nest clearance to that edge or you'll need a UCS to do it.
I posted a UCS on the CV forums that automatically adds everything needed whenever there is a visual miter in CV.
Gotta wonder- why are you not on support if you have all these questions to ask? That's what it is for.
4/28/14       #3: Cabinet vision tool operation ...
Bob Member
I 'm looking for private support
4/29/14       #4: Cabinet vision tool operation ...
steve Williams
Website: http://www.johnsamuelinc.com
So Jonah
Do that mean that I could make a one piece miter folded box with the ics and the bit.
That sounds like more of a wizard thing
Steve
4/29/14       #5: Cabinet vision tool operation ...
Jonah Coleman  Member
Website: http://www.fletcherwoodproducts.com
You can set the wizard up for miter construction, and my UCS would add the actual miter ops and additional nest spacing required for those edges. You'd have individual parts though.
If by 1 piece you mean a single piece with miters, you'd need to use a UCS to add a hidden piece of the correct length with the operations required. That could be done.
4/29/14       #6: Cabinet vision tool operation ...
Steve Williams Member
Thanks Jonah!
