Computer Aided Design
smooth wavy lines in ACAD w/o faceting?
12/20/14
Lee Member
How many line segments in a wavy polyline are too many before one blows up their cnc machine?
I'm trying to draw a wavy line about 15" long. It can't be faceted at all. Very organic looking.
So, I have two questions:
1-It's easiest for me to draw the shape I want with the spline tool. Do I need to convert this line to a polyline when I send the dwg file to the cnc? (The CNC runs on Millwright 6.)
2-When drawing a 15" wavy spline I can convert it to a polyline and then specify the precision from 0-99. Roughly what number along that range would remove faceting, but not bog down the program?
It would be a lot easier to test this out on my own if the shop wasn't 30 minutes away. So unfortunately I can't walk over to the machine and run a test cut.
I'm running autocad for mac 2015.
12/22/14       #2: smooth wavy lines in ACAD w/o facet ...
TomO Member
Website: http://www.stgermaincabinets.com
Hello Lee, My experience has been that the CNC post processor will not process a spline because it does not have fixed geometry. You can create tangent arcs by this process, draw an arc, hit the enter key twice, any additional arcs will be tangent as long as you continue in that way. Arc, enter,enter. Hope that works for you.
12/22/14       #3: smooth wavy lines in ACAD w/o facet ...
J Wilson  Member
Lee
Have you tried the "flatten" command on a spline? This will convert the spline into arc segments. Arcs are a good thing for cnc work.
Tom, nice tip. This will come in handy.
John
12/22/14       #4: smooth wavy lines in ACAD w/o facet ...
ozan
if you can import dxf , than make the arch in cad.
12/26/14       #5: smooth wavy lines in ACAD w/o facet ...
Lee
Thanks for your feedback folks. :)
