Computer Aided Design
Cabnetware Intelliparts
2/24/15
Richard Member
Does anyone know how to get an Intelliparts file to relate to a specific room in Cabnetware? We have an Intelliparts file edited just the way we want it, but if you import the job cutlist into the CNC center and select that Intelliparts file, it doesn't apply the correct machining. We are guessing there is a setting within Cabnetware that you have to select the Intelliparts file first. Not sure.
2/27/15       #2: Cabnetware Intelliparts ...
KD
You can attach a Template from S2M to a construction file in your parameters setting but not a specific intelli part.
There are ways to link intelli parts to specific cabinets through material parameter files and names but I would need to know exactly what you are doing to guide you.
12/5/18       #3: Cabnetware Intelliparts ...
Michael Murphy Member
You can assign a particular template(intelliparts) set to a construction file that will be used for parts for cabinets that were designed using that construction file. It can be an entire room or just one cabinet in a room.
The selection of the templates at the construction file level wverrides whatever is chosen while importing the cutlist into CW CNC.
It has nothing to do with materials.
