Computer Aided Design
MICROVELLUM GRAIN DIRECTION
3/3/15
MICHAEL Member
HI ALL JUST LISTING A TIMBER VENEER KITCHEN AND I NEED THE GRAIN TO RUN HORIZONTAL AND I CANT SELECT THE GRAIN DIRECTION TO RUN IN THE WIDTH INSTEAD OF LENGTH IN MY MV STANDARD WHEN IM SETTING UP MY MATERIAL. IF ANYONE COULD HELP THAT WOULD BE GREAT. THANKS
3/8/15       #3: MICROVELLUM GRAIN DIRECTION ...
Gary B.
Hi Michael,
It may help if you list what version you are on, and which library. There are many variables here. Are you trying to "Perfect Grain" between cabinets? If so, I'm pretty sure you're in for a manual process. Perfect Grain only works within a product, and I'm pretty sure only vertically. If you can list what I referenced above, we should be able to get you rolling again.
3/21/15       #4: MICROVELLUM GRAIN DIRECTION ...
Scott R Smith  Member
Website: http://www.caseworkcadcam.com/
If you go to the subassemblies tab for a drawer front, and look at the width and height column cell. You should find a formula like
=IF(Drawer_Front_Type="Generic Slab",IF(OR(G!Drawer_Front_Grain_Direction=1,G!Perfect_Grain=1),Top_Drawer_Fr
ont_Height,Drw_Frt_Width_Calc),Drw_Frt_Width_Calc)
This means that the drawer front looks to the global ‘G!Drawer_Front_Grain_Direction=1” to determine how the part is rotated
Hope this helps,
Scott Smith
http://community.microvellum.com/forums/p/5129/20017.aspx
3/26/15       #5: MICROVELLUM GRAIN DIRECTION ...
Luke Vickery Member
Website: http://www.calwoodinc.com
Michael - were you able to find a solution? If not, we recently went through the same issue and found a resolution. Let me know if you need additional help.
12/10/15       #6: MICROVELLUM GRAIN DIRECTION ...
Derick Ruiz
Website: http://www.con-cab.com
If you turn off (G!Drawer_Front_Grain_Direction=0) doesn't take care of the doors. If you want to have a vertical grained material to be horizontal, you have to force your sub-assemblies to go with "width", and the same thing with your finished ends. After that you have to go to your tool file and allow to rotate those pieces.
12/10/15       #7: MICROVELLUM GRAIN DIRECTION ...
Gary B.
This is handled much, much better in the newer versions of the frameless library with the latest software build, you can change it right in the global settings and it funnels through your project, or you can change it right on a specific part with one click.
This was a major improvement in the software that happened recently.
