Computer Aided Design
Learning Curve: eCab to CV
11/10/15
Tony Member
Wondering what to expect getting up to snuff in CV from scratch? Is it that different than eCab?
At some point I will probably get CV free trial to see 1st hand but would like to know if others have gone this path and what to expect.
11/10/15       #2: Learning Curve: eCab to CV ...
Hi Tony,
Are you running a thermwood with ecab?
I built my business with ecabs,cut 5-6 million dollars worth of work with it over the years. I
also have started using CV, what I can tell you is they are a different beast. If I were only doing residential, I would have stayed with ecabs.CV is quicker for commercial,much more automated once you get your construction methods tuned in.
11/10/15       #3: Learning Curve: eCab to CV ...
Tony Member
Hi Mike,
no I'm not running a Thermwood with eCab. Just create a batch and send out for parts to be cut.
My angle with CV has to do with working for someone else that specifies design, engineering and sales position with experience in CV. So it would be in that capacity. I have to assume that there would be a extra layer of personnel for CNC running and tweaking. So basically design and create a final file that will go into the production department smoothly.
4/24/16       #4: Learning Curve: eCab to CV ...
Y.Heller Member
Not to sound like a jerk here or highjack this thread in any way, but what does CV stand for? Cabinet_____?
I am just starting to look at programs to design/model/ and translate direct to cutlists. I signed up for ecabs, but I want to also look into other programs that other professionals are using.
4/24/16       #5: Learning Curve: eCab to CV ...
Y.Heller Member
I got it. Cabinet Vision. My apologies for wasting posts.
