Computer Aided Design
hinges all over the screen
4/20/16
laxmi
I see Hinges all over the screen. Not sure how to fix it. Your help is highly appreciated.
View higher quality, full size image (1366 X 768)
4/20/16       #3: hinges all over the screen ...
Joe Member
Did you recently upgrade to version 9? If you did and you have UCS' effecting the hinges, they are probably messed up now and you'll have to re-write them. Try turning off all your UCS' and creating a new job and test to see if this still happens.
4/20/16       #4: hinges all over the screen ...
Joe Member
UCS's created in eariler versions than 9 have not been behaving well in version 9 and may need to be edited.
4/21/16       #5: hinges all over the screen ...
laxmi
thanks everyone for your prompt response :) it was related to the UCSs..by mistake I created a new UCS without giving it any properties so it took the default settings which was a 45 Hinge. All I did was to delete the UCS and it got fixed...
