Computer Aided Design
AutoCAD LT 2008 disk missing
9/21/16
B.H. Davis Member
I run my licensed version of AutoCAD LT 2008 on an old stand alone PC. I just discovered I'm missing the installation disk.
I've been in touch with Autodesk support and they said there is really no other option here as 08 is no longer available for download.
Would anyone have a copy of LT 2008 that they could burn a back up disk for me? As I said I have the license.......just not the installation disk.
Thanks,
9/22/16       #2: AutoCAD LT 2008 disk missing ...
Robert Harkleroad
Closest I can Get is 2006. Let me know if that helps.
9/23/16       #3: AutoCAD LT 2008 disk missing ...
Brad Member
If you are unable to acquire a copy of your AutoCAD LT 2008 install disk AND you are dealing with flat, 2D drawings - then may I suggest DraftSight?
DraftSight is a DXF/DWG compatible product that uses the same interface structure as AutoCAD. And it is FREE.
http://www.3ds.com/products-services/draftsight-cad-software/free-downloa
d/
DraftSight® FREE* CAD Software Download
9/23/16       #4: AutoCAD LT 2008 disk missing ...
B.H. Davis Member
Thank you to everyone who responded.....especially David who went out of his way to send me a copy.
In the end I found the missing disc. This morning I was pulling another program CD out of my CD storage case and noticed that the AutoCAD LT disc sleeve I had labeled as an 07 version was actually mislabeled and was my missing 08 disc. I had seen the sleeve image online yesterday so immediately realized the error.
Original AutoCAD LT 08 disc is now labeled correctly and right where it belongs......as it turns out had always been the case.
Thanks again,
10/16/16       #5: AutoCAD LT 2008 disk missing ...
Fred
i have auticad 2017
if you need it just message me
