Computer Aided Design
Microvellum Automated 2D Dimensions/Door Reveals
11/23/16
Frank
I do know the 2d Dimensions/Annotations in the program can be set-up to be automated. How that is exactly done, I am unsure. Out of the box the program came with a few set-up for a 2D cross section. If you click on part properties, then click the Prompts tab at the bottom and click the views to the right you can see the drawing tokens that are set-up for the 2d drawings.
I understand that you have to add a new token 'DRAWDIM/DRAWLINE' but I still am very unsure how you type in the formulas in the bottom to get the correct dimensions I am looking for. Basically I am trying to set one up that does a cross section and dimensions all door/drawer faces, reveals, and the overall height and depth of the cabinet. Does anyone have any example formulas to get something like that to work? Or have any advice on how to set-up the Start and End X,Y coordinates to get it work? I see a +or=G! command in those formulas and I am not sure what that is doing exactly either. Thanks
12/1/16       #2: Microvellum Automated 2D Dimensions ...
Frank
Just an update, I have successfully gotten all the custom drawing token set-up. The G! command in the code means it is a Global command which means the variables won't change when you update the cabinet (ex: Face Frame Inside Overlay) but things that they call out as 'Local' (ex:Toe_Kick_Height+Bottom_Rail_Width) dimensions will update when you change the cabinet. Some of the formulas can get pretty finicky and quite long depending on what you are trying to auto-dimension. I'll give you an example of an upper bottom rail dimension ex: Start Y: =HeightAboveFloor-Height End Y: =HeightAboveFloor-Height+Bottom_Rail_Width and in that token I have both the start and end X set to =-Depth which bring the dimension to the face of the cabinet. Seems that you could spend some time and really force the program to dimension/annotate just about anything you want. X coordinates is left to right on the cabinet, Y coordinates is up and down. Your welcome....
