Computer Aided Design
Microvellum Top Drawer Auto-Changing and Stretcher w/o Mid-Rail HELP
12/9/16
Frank Member
I am in the middle of designing a face frame kitchen. There are many ways to put a bank of drawers using the 2015 Face Frame Library. One method is to use their MV stock drawer cabinets, another is to insert a sub-assembly by picking corners using a 3 drawer bank, or using the vertical splitter option. I have two problems going on in this job I am having trouble working around. Lower cabinets get 3 bank of drawers - inset drawers, with 5 piece generic cope and stick drawer faces. Everytime I change the top drawer height to something less than 7-8 inches it automatically becomes a hardwood slab, even though the drawer rails are only 1.5" wide. There must be some type of global setting thats making them revert to slabs when under 7 inches and I am not sure how to change that. The second problem is there are no mid-rails on these cabinets. There are only stretchers behind the inset drawer faces. Everytime you choose their stock base drawer cabs, there is no way to remove the mid-rail, only by 0ing or physically deleting the part from the part properties which makes the cabinet/reveals 'stupid'. And if you choose their drawer bank option from sub-assembly and pick corners, their is no stretcher/web option in the sub-assembly prompts. If you choose vertical splitter opening sub-assembly, you can put a stretcher inbetween the drawers, but there is no way to remove the mid-rail, only 0 or delete part-which makes the cabinet/reveals stupid......Any help or incite would be very helpful thank you
12/9/16       #2: Microvellum Top Drawer Auto-Changin ...
Lenny Scianna  Member
Website: http://www.microvellum.com
Frank
The 2016 Face Frame component library has this out of the box. But for your library, give this a try. Draw a 1 Drawer Open Base cabinet and remove the shelf in the lower area. Using the Subassembly insert interface, add a “2 Drawer” insert and use the “pick corners” to define the lower opening.
With a couple more steps you can make this product parametric and save it back to your library. Just update the Width, Height, Depth, and Origin cells of the subassembly you added. You can pretty much copy another set of cells from another subassembly like the bead frame. Then save the cabinet back to your library.
If you’re on MV support, come over to the MV forums. We can help you more over there. Good Luck!
12/9/16       #3: Microvellum Top Drawer Auto-Changin ...
Frank,
Your first question was regarding the solid wood drawer fronts turning into a slab at a certain size. To control this, open up the Door Wizard UI, open the LookUpTables UI, find LookUpTableDoor and scroll over to column 13 which is called “Drw Front Min Height”. This is what controls the point at which it changes to a slab. Find the door name you are having trouble with in the first column and set a new value at column 13.
