Computer Aided Design
Microvellum adding 2nd Mid-Rail to Appliance Panel
3/1/17
Frank Member
Hey everyone, been struggling for this one and gave up. I'm trying to create tall appliance panels/columns for a kitchen that require two mid-rails in the framed 5 piece panel. In the prompts there is a checkbox to add a mid-rail but there is no option to add another one?? I also tried doing the same thing with a Misc. Back Panel product and a Wall Panel product to no avail. After those attempts failed I used the part properties/design data to shrink and move panels and copy the mid-rail to create my own. After modifying and moving 1 of the panels, my stick and cope disappeared on my hardwood door parts. Failed miserably. Surely Microvellum has come up with a way to add 2 Mid-Rails to a panel or door?? It seems the further we go with the face frame cabinetry in the program the less the program is capable, and even some products/parts of the software left unfinished? Thanks for reading.
3/1/17       #2: Microvellum adding 2nd Mid-Rail to ...
david wishengrad
You are going to shoot yourself in the foot Frank.
Machining tokens are based on criteria. If the criteria is there it should work fine.
3/6/17       #3: Microvellum adding 2nd Mid-Rail to ...
Gary B.
Frank,
Just curious, but have you tried going into the subassembly prompts for that item? (one level deeper than the product prompts). Sometimes you get lucky and the subassembly is actually more capable than the product prompts let on. If not, you'll need to dig deep to make the data do what you want in your own subassembly, then update your library with that new data. It's all possible, I did it myself at a past company, but it will take some work.
3/6/17       #4: Microvellum adding 2nd Mid-Rail to ...
Frank Member
Gary - No there is no sub-assembly I have found in any part of the program that will allow you to add a 2nd Mid-Rail to ANY of their existing products. I'm talking applied finished returns, any type of door, wall panel, back panel nothing. Which makes me question where they plan on going with these face frame features within the program. Why make them available if they only finished half the program/libraries ability to design custom features. As for you David, machining tokens are great..if you are trying to dado a part, if you are putting in an access or utility hole in the back of a cabinet, not for designing a column with an 2 mid-rails. Thanks for your guys help
3/6/17       #5: Microvellum adding 2nd Mid-Rail to ...
Lenny Scianna  Member
Website: http://www.microvellum.com
Hi Frank,
Wondering what version of the library are you using? Gary is correct in that sometimes the subassembly prompts contain more detailed construction options to explore. This is more true in some of the newer library versions.
Here is a screen shot of a Tall cabinet with 2 mid rails at the side applied panel. We can also specify what the adjacent condition is to accommodate a base & upper to bump, for example. So you might consider taking this subassembly and modifying it to accommodate an appliance panel like you describe. You can also inquire with the community of other MV users over at support.microvellum.com. Perhaps someone else has already created one.
Next month Microvellum will be releasing a new version of its library. This version contains a large amount of new products and features geared for the residential market specifically. You can stay up to date with what’s coming out via the MV YouTube channel, or if you really want to learn more, come out and join our technical conference on April 27 & 28. MV will be providing a variety of workshop training classes that you can choose from. There will be two options dedicated to the library data itself. One all day beginner level and one all day advanced level. Considering the current cost of one on one training, this event is an inexpensive way to get some specific training to advance your MV skills. www.microvellum.com/techcon2017
If for anything else, you will have the opportunity to petition directly to the MV developers what you feel is missing in the program/library data. Even better appliance panels!
View higher quality, full size image (929 X 965)
View higher quality, full size image (860 X 958)
    • ECabinet Systems
    • INNERGY
    • Cabinet Pro
