Computer Aided Design
Alphacam lag issues
9/17/17
Ian Member
Our company has recently purchased a seat of Alphacam ultimate router, and a hp Z book to run it on, but it has serious sporadic lag issues, sometimes it freezes up to the point where the program becomes non responsive. The computer this runs on has an i7 processsor, but it is two core. Minimum requirement call for Minimum Specifications
64-bit Intel Pentium 4 processor (2 GHz or faster), Intel Xeon, Intel Core, AMD Athlon 64, AMD Opteron, AMD Phenom or later, in single, dual or quad core versions
4 GB of RAM
To make the most of background processing and multi-threading, we recommend a 64-bit operating system and 2GB RAM for each processor as a minimum.
Please ensure the latest WHQL certified driver that supports OpenGL 3.3 for the card is installed.
Note: Some older cards in the ranges above may no longer be supported. Please check the relevant supplier to see if an up to date driver is available for your operating system. Other graphic cards may work, but are unsupported.
10 GB free disk space for the Alphacam installation
Graphics cards - Driver requires OpenGL 3.3:
NVIDIA Quadro range (www.nvidia.co.uk/Download/index.aspx?lang=en-uk)
AMD Fire Pro range (http://support.amd.com/en-us/download)
Could the amount od cores be the issue?
9/18/17       #2: Alphacam lag issues ...
Marek Skotak
Website: http://www.cadcam-softcz.cz
Hi,
which graphics you have on you HP?
9/18/17       #3: Alphacam lag issues ...
Ian Member
I spoke with A cam this morning, said the card should be satisfactory. AMD firepro
9/27/17       #4: Alphacam lag issues ...
Ian,
I have run Ultimate on my hp mobile workstation and HP Desktop with no major troubles. I noticed that multidrill operations are very slow on my machines when the 64 bit version of the software is installed. Uninstalling that version and putting on the 32 bit version solved the problem. Other than that, both 32 and 64 bit run fine.
