Computer Aided Design
a show of hands...
5/24/18
Peter Matos Member
I was thinking it would be interesting to hear from everyone on here about what Cabinet software you all are using and perhaps a short review of what you think of it and what you are making with it? I am currently reviewing several different software packages for cabinet design for our shop and it is a difficult decision. We are wanting to be able to do high quality 3D renderings as well as have a good CAM capability/flexibility. The ability to design many different cabinet types and closet installations etc. I am sure there are even packages we are not currently aware of. If you also are using a CAD CAM package for custom non cabinet related pieces it would be nice to hear what you are using and how you like it? Perhaps this could be handy for other people in a similar situation. I have been searching this site and others for information and reviews on the various softwares and trying to determine what our best option would be. Thanks in advance for any suggestions/reviews.
Pete
5/24/18       #2: a show of hands... ...
We have run Cabinetsense Software plugin for Sketchup for years and couldnt be happier. The complete flexibility with the integration in Sketchup allows for a versatility we have not seen elsewhere. In addition our work is often part of a much larger project in both commercial and residential applications and being able to quickly 3D model spaces outside our work and show interfaces with existing or field measured work is very beneficial. The ability to apply many different styles and edge profiles allows us to get away from the typical blocky rendering style more commonly seen when needed.
The particular job has to of course have the budget for that level of detail but when it works in our favor it is splendid.
5/24/18       #3: a show of hands... ...
Peter Matos Member
Interesting... have not heard of that one before. Does it do photorealistic renderings inside sketchup? I will have to check it out... Thanks for the suggestion..
Pete
5/25/18       #5: a show of hands... ...
Yes, several photo rendering options. It just depends on how much effort you need to put in.
5/29/18       #6: a show of hands... ...
Brian
Microvellum Toolbox. But only if you want the best. It is only limited by your ability to learn. Might not be the easiest to learn nor the least expensive but if you are working with one offs or doing a lot of commercial work there is nothing on the market that can compare. Again the ability of the user to actually learn the software is the deciding factor.
5/29/18       #7: a show of hands... ...
Peter Matos Member
Brian,
Thanks for your post. We are looking at microvellum but as one of the most expensive we are kinda waiting until last to look at it. I did view a few youtube videos about it. Seems like it is more of a CAD program than a specific cabinet program. What does a single fully loaded seat cost from them? As a custom cabinet shop that is doing a lot of different things all the time your comments on it make it more attractive now. As far as learning the software that should not be a problem I have learned several CAD CAM packages over the years and used Ecabinetsystems a while as well. Programming in Mastercam on the metal side as well as solidworks etc... Is it that complex that you remarks about it set it apart from these others?
Pete
5/29/18       #8: a show of hands... ...
Im an inherently skeptical about software options that dont directly list pricing or even price ranges and want to get you "on the hook" before you even know what your in for. Microvellum is one of these. You can scour their site and find product "tiers" pages but you have no concept, on a looking-at-options basis, of what your looking at? 3K? 8K? 12K? Pay as you go? Monthly? Volume based?
If your a varied shop these are not solutions or options.
5/30/18       #9: a show of hands... ...
Dan
I use the following software:
For Drawing: AutoCad w/ Smartlister and Solid-Cim, Inventor w/ WoodWork for Inventro and Solid-Cim
For Part Processing: SmartLister and Solid-Cim
For CAM: Router-Cim
For Saw: Ardis
For BOM: Excel, import CSV files from software.
The products we make are custom one off fixtures. Some production type work. I have used a couple other programs but found it difficult to fit custom products into the other software I have used.
6/8/18       #10: a show of hands... ...
Peter Matos Member
Thanks Dan and Mark I appreciate your responses. We are still evaluating software here as our CNC becomes setup and powered up. Any of you guys use Microvellum to design cabinets for high end custom work? It looks quite interesting but the price is high.
7/30/18       #11: a show of hands... ...
Charlie W Member
We use Autocad to do takeoffs and sometimes shops, CV for everything else.
