Computer Aided Design
Alphacam manual part flip with program stop
10/11/18
Ian Member
I'm trying to make a program in Alphacam that will require inserting a program stop and flipping the part, but how do I get it to read that the bottom is now the top as far as machining?
10/12/18       #3: Alphacam manual part flip with prog ...
MIKE COLLINS
maybe this can help
10/12/18       #4: Alphacam manual part flip with prog ...
Ian Member
I saw that video before, but what tells the program/cnc that the underside is the new top? Does the part need to be turned in the program in reference to the global when the tool path is applied?
10/16/18       #5: Alphacam manual part flip with prog ...
Marek
Website: http://www.cadcam-softcz.cz
Hello,
depend on which machine you have. Ussualy in ISO code programming it is command like M0. So when you will add this option (in a video) in a postprocessor will be activated routine "programme stop" and input to a code some sequence of a code.
Like
M5
G0 G28 Z0
M0
(rotate part and start program again)
G0 Z..
etc
But as i said command for a program stop can be different by a drive control.
Hope it helps.
Marek
11/19/18       #6: Alphacam manual part flip with prog ...
Ian
I ended up having to use NC Hops program stop, basic Alphacam program stop will not post to NC Hops. I then had to copy some repetitive operations into the operation chain.Not really the way that I wanted to do it as it can not be viewed in simulation, but it works.
