Computer Aided Design
AutoCAD Setting
10/22/18
In the past 6 months or so, I must have changed a setting in AutoCAD, or an update changed a setting for me, but I am having a problem with snaps. 2d and 3d snaps work fine, but when I import a raster image, I am no longer able to snap to the end points of the image for scaling, rotating etc. Anyone know the fix for this? Thanks.
10/24/18       #2: AutoCAD Setting ...
Thomas M Diel
Website: http://thomasdiel.com
I feel that raster images have so many Osnap points that it helps to do a ctrl + right click to narrow the scope of what Auto Cad is trying to grip to when I am over tracing / scaling etc. I pick end points from this process to keep it simple and also do frequent save or save as helps with that lag that heavy memory usage raster images bring in. Once finished I delete the raster and purge the file back to smaller memory needs. I do keep the raster image in the project file if needed later. Sorry if this is remedial info to you.
Best of luck, TD
11/8/18       #3: AutoCAD Setting ...
Reinstalled AutoCAD and Microvellum to fix the issue. No clue as to why the snaps stopped working on raster images, but a do-over on the installations cleared the issue for me.
7/14/20       #4: AutoCAD Setting ...
Sheldon Silvers  Member
Sir, if you're still having this problem, please consider uninstalling this software from your machine and install fresh software again.
    • INNERGY
    • Cabinet Pro
    • ECabinet Systems
