Computer Aided Design
Cut-Rite V9
12/19/19
Ex-Pat Member
I am having a little difficulty figuring out how to prioritize the sheet selection in Cut-Rite. Basically, I have several different sizes of particle board and laminate sheets for making counter tops. I want to force it to use the smallest possible sheet for a part. Right now, tops and laminate that would fit on 4x8 material is being put on 30x120 and 30x144 instead - the waste factor is almost nil, but the longer sheets are a PITA to receive, handle, and store. I would much rather have a higher waste factor and fewer of the large sheets. Does anyone know how to achieve this, or maybe be able to point me to a video to help me figure this out?
Thanks in advance
12/21/19       #2: Cut-Rite V9 ...
Doug
Ex-Pat,
I have V-10 so forgive if this feature is not in V-9. If you go to the part of the board library where you can set up different size boards there is a column called usage where you can assign different values. Value 8 is unlimited stock and value 9 is use if no other boards. Assign those accordingly. You also may want to change the cost of material on the board you only want to use if that is all that fits to a much higher cost than the other. Also, make sure in your optimizing parameters that consider cost is checked. i use this for my back material as we like to use 30x120 sheets of hardboard as they are easy to work with but still need some 4x8's for the 36x36 upper cabinets etc. Try manipulating these combinations until you get what you like. you make also want to apply a material parameter to one of the boards to further affect your outcome. Unless you tell it to it will optimize the fewest square footage possible with the boards you say are available.
12/23/19       #3: Cut-Rite V9 ...
Ex-Pat Member
Thanks Doug. V9 seems to have the same features (whether or not they function the same, who knows). I tried setting the other sheets as 9 instead of 8, it didn't really change my results at all. I was toying with the material cost idea, glad to see I was on the right track. Next fly in the ointment - if it choses a larger sheet size but the larger sheets are more "expensive", will it use the drop from that sheet before going back to the smaller sheets?
12/24/19       #4: Cut-Rite V9 ...
Doug
Ex-Pat there is always a price to be paid when you lie to your software. Possible that my advice was not the best about changing costs. I have never really put drops into the equation before so i have not had that issue. I did run a test and changed my material cost so that they were all the same and still got the results is was looking for. If it is still choosing the larger board keep looking at the parameters as i would guess it is somewhere in there. Cutting time, rec-cuts or something like that is affecting it.
12/24/19       #5: Cut-Rite V9 ...
Ex-Pat Member
Thanks for taking the time to look into that for me, I appreciate it. You've pointed out a couple avenues to explore which is great. Have a Merry Christmas!
2/25/20       #6: Cut-Rite V9 ...
No Idea
In general you got 2 options.
1) Obviously you can delete from the board list of that job any board size of a material you don't want to use.
That will not delete the board from your library - it is only deleted from the board list for that particular job.
2) If you enter as quantity for the board you want to use the quantity available for the job and limit 8 and enter for all other board sizes as quantity 0 and limit 9 (again - can be done just in the board list for that job!) CUTRITE should only use the quantity of your favorite board and select for further sheets the best yield option for the other sizes with limit 9.
I tried that for other jobs in V10 and V11 successfully and guess it will work in your V9 as well.
    • Cabinet Pro
    • INNERGY
    • ECabinet Systems
