Computer Aided Design
Cabinet Vision security key
4/18/20
Cobby Member
I just tried us CV and it says security key not found. The key is plugged in and the light is on on the key. I've plugged in other USB devices and they work. Has anyone else had this problem before and what was the solutions?
4/18/20       #2: Cabinet Vision security key ...
Jim Diebolt
Website: http://forum.designsbydiebolt.com/viewforum.php?f=...
When this happens with Cabnetware it is because it needs the Sentinel System Driver Installed. Could be the same for CV.
4/20/20       #3: Cabinet Vision security key ...
Bob Lewis Member
I've had this problem sometimes. I have found that the PC won't recognize the security key if I insert it after the PC has started.
If I plug the key in and reboot the computer, it works every time.
4/21/20       #4: Cabinet Vision security key ...
Tyler
You may have to go to CV utilities and run their serial key finder, especially if you are financing it.
4/28/20       #5: Cabinet Vision security key ...
Colby Member
Website: http://cabinetworksva.com/
Check the License manager. If its a drafting key you should see the manager say "solid drafter" while an ultimate key would say "solid ultimate".
Then check to see if the Lock Code and Server Code match up with your key on the Vero Customer Portal website. We had this issue recently and it was caused by incorrect lock codes on our keys.
    • ECabinet Systems
    • INNERGY
    • Cabinet Pro
