Computer Aided Design
Alphacam Vba for Geometry Z-level
12/24/20
Anshu P Member
Hi All,
I am trying to access bottom z-level of geometry using vba in Alphacam.
But I m not able to find any object or property for that.
Can anyone please suggest how can we get the bottom z-level value of geometry?
12/26/20       #2: Alphacam Vba for Geometry Z-level ...
David Wishengrad
Are points not defined by x y and z?
12/26/20       #3: Alphacam Vba for Geometry Z-level ...
David Wishengrad
I have never coded for Alphacam. Generally speaking, when I want to bottom z of something, certain geometry will have that value which may defined as elevation.
One way to get as it if it does not is breakdown what is there with an explode of a copy to get to points or to use a boundingbox method if available.
Another may be there requiring .NET or just c++.
I feel pretty sure there is a boundingbox method.
This question is best posted in the CNC forum. There are many over there that will know, and be about to possibly just toss you a code snippet right away.
There was an Alphacam forum, before the company changed hands and probably still is. Good luck.
12/28/20       #4: Alphacam Vba for Geometry Z-level ...
Ian
I use report coordinates
1/3/21       #5: Alphacam Vba for Geometry Z-level ...
Kris Member
I have been using the extra info in the bottom of the Layers tab
the data comes after a weirdly long name
I've attached a jpeg to show you where
in my case, material top is 1", bottom is 0
View higher quality, full size image (679 X 853)
1/10/21       #6: Alphacam Vba for Geometry Z-level ...
David Wishengrad
Good stuff. I don't know about rounding errors in a parasolids based app like AlphaCAM.
I can tell you that I would never trust a boundingbox method from AutoCAD or another ACIS based cad program if it was critical, without first translating and transforming the object to be planer to the xy and and a long edge parallel to the x, due to rounding errors on the ACIS kernel.
1/12/21       #7: Alphacam Vba for Geometry Z-level ...
Ian
Kris, why not 0 for material top, and cut negative?
    • ECabinet Systems
    • INNERGY
    • Cabinet Pro
