Computer Aided Design
Bsolid Programming
7/16/21
Kalvin Cackler Member
Website: http://woodhavencabinets.com
I am really need help with someone who knows Bsolid.
We are needing help tweaking a program we wrote to size our doors. There are still a couple of hiccups:
#1: Have to manually change origin to 5 every time I run the program
#2: It does not cut the door on the 2 edges that are against my fence. Is there a way for it to trim 1mm off those 2 edges?
#3: I need the program to first back cut the two end grains about 3" to prevent blowout.
If anyone could help me out here, I would be extremely grateful.
7/25/21       #2: Bsolid Programming ...
David
Kalvin, I had to write a similar program when we started making doors.
1. Double click on the Piece listed under Geometries and Machining on the right side of the screen. input 5 in the text box "List of origins".
2. You need to make a parametric rectangle that will represent the finished dimension. This rectangles first point should be x1,y1,z0 if you are trying to trim 1mm off the sides against the pins. second point should be something like lpx-1, lpy-1,0.
3.I use a counterclockwise bit for this. make a parametric line that uses the same variables as the rectangle, and has a length of 3". I can upload my program for you to study if that would help. We run a Rover K pod and rail machine.
7/26/21       #3: Bsolid Programming ...
David, that would be great. We do all of our design in Mozaik, so I really know nothing about Bsolid. We are running a Rover K FT. If you want to email me your program, that would really help me out! Thank you.
    • Cabinet Pro
    • INNERGY
    • ECabinet Systems
