Computer Aided Design
Cabinet Vision - How to apply laminates on Drawer/Door Fronts
10/21/23
Arpit Member
Cannot find these options to apply Laminate on Door/Drawer Fronts. Please see the attached file (Yellow highlighted options)
I' working on CV 2023. If these options have been redacted, how does one go about achieving the same thing?
View higher quality, full size image (789 X 564)
11/22/23       #2: Cabinet Vision - How to apply lamin ...
Pdub Member
You handle that with the material now. Look up "Composite Material" in the help file.
12/10/23       #3: Cabinet Vision - How to apply lamin ...
jorginho
You can manually edit the part's XML file to apply the laminate material.
4/26/24       #4: Cabinet Vision - How to apply lamin ...
waderatke
Website: https://basketball-starsgame.com/
You have the option of manually modifying the XML file that represents the part in order to apply the lamination material.
4/26/24       #5: Cabinet Vision - How to apply lamin ...
David Wishengrad Member
You could also write a piece of code to quickly edit xml's as needed.
    • INNERGY
    • ECabinet Systems
    • Cabinet Pro
