Subject: Re: CNC Machining Recessed Panel MDF Doors
9/3/14
Brian Member
Any tips on reducing CNC machining marks left on recessed panels of MDF doors?
We are experiencing a huge spike in demand for this RTF door style, and I would love to see a reduction in post-router process time.
I currently employ a square corner 40mm 3-wing diamond-tipped bit in an HSK63 collet-type tool holder to hog out the center of the door.
My tool path is helical (spiral), cutting in the clockwise direction, starting from the center of the door.
Toolpath overlap is minimal.
Prior to pressing, sanding time is (minimum) 1-2 minutes per door.
I am a firm believer that overlapping toolpaths will never be perfect, but I'm confident that improvements can be made!
Thanks in advance.
9/3/14       #2: CNC Machining Recessed Panel MDF Do ...
Johann Huck  Member
Website: http://www.themachinewarehouse.com
Brian,
There are a few types of things can help improve the cut quality. Can you post a picture of the type of cut quality you are getting off your machine?
The first would be the type of MDF you are using. Not all types produce the same finish when pressing.
Next would be to adjust the overlap on the tooling and also with the speed of machining. It also could be the spindle might need some fine adjustment to improve your cut quality. Manufacturers have their tolerances for spindle alignment, but it can usually be improved upon by taking the time to align a spindle.
The final step would be to control the climate for the MDF as it comes in, sits, machines and then presses. Humidity and temperature can all affect it and cause problems. Some have problems letting the board sit overnight prior to pressing. Some people don't, it depends on the climate.
Johann Huck
The Machine Warehouse, LLC.
704-839-6615
johann@themachinewarehouse.com
9/3/14       #3: CNC Machining Recessed Panel MDF Do ...
james mcgrew
Website: http://mcgrewwork.com
when you say "Overlap is minimal" I presume you mean "stepover" if minimal is above 45% then consider changing it. I get far cleaner cuts and less heat on bit I can run faster as well
9/5/14       #4: CNC Machining Recessed Panel MDF Do ...
Frank D. Jimenez  Member
Website: http://www.cabinetpro.com
I noticed you mentioned that your direction of cut is clockwise. You may want to try cutting in a counter-clockwise direction. We have found tools not only last longer when cutting in a counter-clockwise direction, but the cut is much cleaner.
-Just a thought.
