Subject: Re: Winner90/Win95 OS
Winner90/Win95 OS
12/8/14
Brian Personett
1996 Busellato Optima, 486/66 running Win95. My battery died causing my bios to reset. I have managed to get WinCode to run again. Does anyone know what change I need to make in order to run the machine in manual mode? Currently when I attempt manual, it tries to start and just closes.
12/12/14       #2: Winner90/Win95 OS ...
Kevin Simmons Member
I don't remember any specific BIOS/CMOS setting for Winner90/Win95 machines. It seems to be an obvious question for someone who is not new to winner90, but I have to ask. Are you shutting down drvptp before opening manual?
My guess would be that drvptp is not releasing control of the serial port for whatever reason.
If any part of Winner90 starts automatically then try stopping that, rebooting, then starting manual diagnostic. This way you should have complete access to the port.
12/12/14       #3: Winner90/Win95 OS ...
Brian Personett
I will give that a go Kevin, yes I am shutting down Driver PTP. After this initially happened, Wincode acted the same way. I had to change port settings in the bios to get it to function, which lead me to believe it was possibly something in the bios. I have never had to shut down anything other than Driver PTP to get manual to run. I can survive without it, but it's a lot easier changing tools if I have it.
Is there anything else that may have possibly changed with the battery dying that would have caused this issue?
