Subject: Re: Anyone running 3 flute compression bits?
2/14/15
Gary B.
I usually run a 1/2" compression 2 flute @ 20 meters per minute (18k spindle) on my weeke nested router for melamine. I usually get good results on both the faces and core.
I have a production run coming 100's of sheets with only a handful of dedicated patterns. I want the fastest cut I can get on these without sacrificing any quality. All of these parts are getting 0.5mm banding which shows any issues with the core.
When I tried a 3/8" 3 flute bit at the recommended chip load, the core was pulling. Will I get a better result with a 1/2" bit?
I'm even considering 3 passes; one through the center of the kerf between parts, then an onion skin pass along each part taking off 0.5mm along the full edge of each part.
I'm very interested in the forums experience here.
Thanks in advance!
2/14/15       #2: Anyone running 3 flute compression ...
cabinetmaker
We have been return onion skinning lately for hold (40HP Vac Pump) and performance of cutting @ outrageous speeds with melamine and laminated panels. The edge is great, dust is down and the banding looks better than before. Vortex 3130 XP from
http://www.cnc-tool.com/
I actually pay less from them than Vortex.
2/14/15       #4: Anyone running 3 flute compression ...
Kevin Bayerlein Member
^ What he said
3130 XP
2/15/15       #5: Anyone running 3 flute compression ...
Gary B.
Thanks Guys....What chipload are you guys aiming for on Melamine? I'm going to get one of these bits this week to try.
2/15/15       #6: Anyone running 3 flute compression ...
Gary B.
Also,
are these 3 flute or 2 flute bits? I'm on the vortex website, but I don't see it listed.
2/16/15       #7: Anyone running 3 flute compression ...
Derrek
+1 on vortex. We run 800 to 1000 inches per minute on 3/4" melamine. My operator is complaining its running to fast and he can't keep up.
